Re: tile mural
Posted: 09 Nov 2012, 17:01
Sorry purpledragon but I think it is over the top to say that WDR's advice is so wrong.
I am fully aware that there are different coatings for mugs and all of them react in different ways. But as a general rule WDR is right in that a coated tile will be the same as a coated mug. If the tiles are purchased from a reputable supplier then it is fair to assume that the coating is going to be of a standard you would expect. Perhaps WDR should have explained that, but personally I do not think so. WDR may be new to the game but I have 15 years plus and his advice, in my opinion, is correct
I have coated my own tiles and also purchased some from BMS. They have all be scratch resistant so not sure where you buys your tiles from.
Back on topic there are a couple of things with this sort of order. If the item is in direct sunlight it will need a UV coating, but it will propbably still fade. There is a member on here that is trialling UV coating but is only two months into the test. Cleaning products are getting stronger and you will need to tell the owner that the cleaners must clean with soap and water only. So if its out of direct sunlight, they follow the cleaning instructions and you get the blanks from BMS you will be fine.
