Page 4 of 4
Re: 3D Vacuum Heat Press - new model ST-2030
Posted: 30 Sep 2015, 09:40
by Post
In the mean time, did anyone have the chance to work with the ST-2030?
Posted: 28 Nov 2015, 13:09
by 386
Hi, two weeks ago i bought the ST2030.
The machine works great, but i've some issues with the film.
I've bought the silver film (the korean kind) and they cracks every time
the machine have a preheating temperature that i've set it to 90°c and the heating temperature to 160°c for 360 sec.
so I turn on the machine and consequently the preheating, when the preheating is done i insert the blank cover in the mould and the film over it, i close the machine and i start the heating, the vacuum turns automatically on but after max 15 sec the film crack and the vacuum aspires to empty
Please someone could help me? I'm going mad with this problem
Posted: 29 Nov 2015, 18:51
by pawelz
I have ST-2030 and still can't figure out the process. Don't have time to experiment at the moment.
I have wasted over 20 sheets of bestsub gold film. Only three times film didn't crack, but the final print wasn't satisfying.
I tried different preheating times/temperatures, jig temperatures and drying method/time, but stil can't find a combination that works.
How do you dry the film?
What printer and inks do you use?
Do you print 1 or 2 cases per cycle?
These videos might help you:
https://youtu.be/pkC0m1C1mks?t=3m11s
https://www.youtube.com/watch?v=calT65-ITrk
https://www.youtube.com/watch?v=vz1_94cFNTk
https://www.youtube.com/watch?v=AO87D5DN8J4 (2:05 I don't understand why they wrapped the jig with tape)
Posted: 29 Nov 2015, 19:12
by astroanalyst
In the first link you showed a bigger machine that seems to be what people have been using for the last few years.
The FreeSub by sunmeta is much smaller and also uses much less power.
What is the difference in quality of these two machines?
Posted: 29 Nov 2015, 19:30
by 386
I am currently trying to make one single case
I leave them to dry over the machine, or keep them for a while on the open machine
anyway the ink will dry by himself in max 2 min.
Posted: 16 Apr 2016, 21:04
by malkram
Did any of you solve this problem of film cracking ?
Posted: 17 May 2016, 04:23
by trecenters
What has been the best Vacuum system as of late?
