Text image blured on mug
cupsforcops
Re: Text image blured on mug
I've now tried, lower pressure, lower time, higher time, higher pressure low time, high time. The only difference is low pressure seems to give a patchy image, some dark, some light. Whatever I do, it's still blurry. The image is still sharp on the paper. I think now, it can only be the mugs! Very annoying!
Dave271069
Morning, Can i make a sugestion, put some images up of the mugs on the thread for us to see, someone no doubt will be able to help or advice you even better, remember a picture tells a thousand words.
Dave
Dave
+1 for this one dave!
cupsforcops, try to higher the temp up to to 190-200C and see what happens. I am not expecting great results but we will see if sharpness improve or not.
cupsforcops
I will do that, good idea. Don't know if a photograph will show it very well, but I'll try. Just trying a photograph now, to see how that looks
cupsforcops
http://www.cupsforcops.co.uk/proofs/P1000909.JPG
This is just a picture of some of my wasted mugs. Can't get one close enough in focus to be able to upload it. I will try using my tripod and posting one later
it would be helpful to take photo of them ptint towards camera
cupsforcops
Yeah I did, this one was just to show you some of the wasted mugs!!!Paul;72702 wrote:it would be helpful to take photo of them ptint towards camera
cupsforcops
These two pictures are of probably the worst one of the lot. This shows really bad bleeding/blurring, most are not as bad as this, but this is a good indication of the problem. Incidentally, just did a photograph one and it is perfect!
www.cupsforcops.co.uk/proofs/P1000914.jpg
and
www.cupsforcops.co.uk/proofs/P1000913.jpg
and
Can I ask a question... do you tape your artwork down to your mug before clamping ?
To me that 'looks' like ghosting off the paper or bleed. Only time I've seen was when paper shifted during print (not taped securely) or didn't come straight off when removed. I dunk all mugs in room temp. water. You'll see the dunk/fan/leave methods discussed in detail on the forum already so I won't go into this but for me at least I need to cool quickly to avoid bleeding.
