Print Pricing and Cost Predictions
Share your hints and tips with other members
James990
Re: Print Pricing and Cost Predictions
Post by James990 »
Yep, but still does not work
logobear
Post by logobear »
worked fine for me, but you do need the Doc X converter. soo many variables, will need some time to play with it later.
Meanwhile.......
I generally price things mostly on how long something will take. Media costs are generally only about 25 - 30% of total sale price, so bearing this in the back of my mind, I try to make sure that actual 'production' time is earning my shop at least £60 per hour.
So roughly, £60 + cost of materials used in 1 hour divided by the number of units 1 person can make in 1 hour = the cost per unit (+ vat if i think i can add it on)
Johnny
Post by Johnny »
James990;71745 wrote:Yep, but still does not work
PM me your email and I'll fire it over to you?
Johnny
Post by Johnny »
logobear;71746 wrote:worked fine for me, but you do need the Doc X converter. soo many variables, will need some time to play with it later.
Meanwhile.......
So does that mean you'll only ever make £60 a day no matter what the cost of the job?
Andrew
Post by Andrew »
That was per hour I believe with LB. I work a similar way to the Bear. If I have a bespoke job then it is costed at a certain rate per person for each estimated hour the job will take. Other costs on materials and running etc are easy enough to workout.
Hi johnny
I have just had a play with this and it looks really good. However I have just tried to insert my own product (in this instance a mug). I copied your coaster line and pasted it on a new line and then simply changed all the costs.
When I then selected from the drop down list on the quote calculator it shows the mug, but when I select it all the values below switch to N/A.
Don't suppose you know what I am doing wrong?
Johnny
Post by Johnny »
the initial copy and paste may have messed up some of the formulars, but somehkw it doesn't seem a likely contender.
star from the initial file and type in a new line. make sure all the sections in coloured outlined boxes are filled in, as well as the qty at the top.
make sure your product title doesn't have and and symbols or similar that may mess up the formulas.
if that doesn't work then post the file back to me and ill take a look.
what version of excel are you using?
j.
Johnny
Post by Johnny »
A little update - I calculated the material/product supplier postage wrong. Divided it against the order qty rather than the pack qty.
www.dosime.co.uk/DyeSubCalculatorPricing-v2.xlsx
dazzul
Post by dazzul »
Just about to take a look, will post back
tlworkwear
Post by tlworkwear »
Will have a look at this as may help me price future jobs in a much better way! Thanks :)
