Photoshop help needed.
Any OS, software in here.
Greensleeves
Re: Photoshop help needed.
Post by Greensleeves »
what file extentions can i upload because psd and jpeg are out for uploading
pat
jpg. but make sure is not to big file. or just send it to me at [email="mugs4us@hotmail.co.uk]mugs4us@hotmail.co.uk[/email]
Greensleeves
I hope you can see this. its small i think
Pat
Greensleeves
this is what happened when i cut
delete that selected layer by pressing del button. draw your circle on layer 0. should work.
Greensleeves
Paul wrote:delete that selected layer by pressing del button. draw your circle on layer 0. should work.
the layer just appeared again. Thanks for your help. I have troubled you enough. I will go further a field.
Thanks Patrick
lol. i can see it clearly now. you didi not followed step by step. u using wrong tool. you need to use second tool from the top.
Greensleeves
Paul wrote:lol. i can see it clearly now. you didi not followed step by step. u using wrong tool. you need to use second tool from the top.
You are right Paul. I used the wrong tool. I am getting great results. Kick me from behind method always works with me. Is there a way i can soften the edges of the circle so that it looks better on the plate? :D
I made little video for you :)
you can have a look on here how to soften the edges of the picture.
[url="http://portrait-snaps.co.uk/feather%20circle.htm]http://portrait-snaps.co.uk/feather%20circle.htm[/url]
Greensleeves
Paul wrote:I made little video for you :)
I have to say you have outdone yourself Paul. I am a fully fledged member of the "i will follow any instructions to the letter". I followed your video and it became crystal clear what i was doing wrong. You have gone to a considerable amount of time and energy to get me unstuck. If you are ever in ireland give me a call. I do appreciate what you have done and you have a firm friend here in the land of the leprehcauns. I have taken delivery of the plates today and you video worked a treat. I like the idea of feathering the edge of the photograph before i sublimate it to the plate as you dont have to have it dead centre.
Thank you again
Patrick Mullan
