Polymer Plate - Different size
Help in finding new products.
Has thanked: 13 times
Been thanked: 12 times
Re: Polymer Plate - Different size
bms;81225 wrote: I have located a 10" ceramic plate as per the design on these pictures. Not sure what shape/ style you are looking for but I think Justin was looking for something alone these lines as well.
Ones I needed were much more shallow than these, almost flat....and have to be polymer I'm afraid....but thanks for the update :-)
bms;81225 wrote:[ATTACH=CONFIG]2301[/ATTACH][ATTACH=CONFIG]2302[/ATTACH]
martin, any idea when they will be available???
Ali P
Post by Ali P »
Paul;81985 wrote:martin, any idea when they will be available???
And I would be interested too - I was after something similar before Christmas (and managed to persuade customer to allow me to do something else instead) but I would still be interested if, as Paul says, the blanks were not too costly and could be bought in small quantities. Probably for printing all over rather than just the middle. I read previous threads about plates where the conclusion was nobody wanted them, which is why the supply in the UK is limited!
chatheway
Post by chatheway »
Hi Justin,
I have been getting quotes for 10" Polymer Plates. I wondered if you are interested in ordering a supply and help split costs with me?
I am waiting on a couple of quotes from China also.
I noticed that BMS said he might be able to get a better deal, so if you are interested, I will see if he wants to divide by 3 a supply also.
I am in the U.S. but I think we could work out logistics.
Justin;68075 wrote:I am looking at buying polymer sublimation plates (shallow) for a customer. The standard seems to be 8" and I've also seen 6" but this particular customer needs 10" plates.
I've been getting quotes to have them made, tooling costs are as you'd expect, £5k - £10k.
Just wondered if anyone had any contacts that might be able to help. This will be a good ongoing/growing order.
Not looking to pursue this at the moment, customer not willing to make the required commitment and questions over required machinery.
chatheway
Post by chatheway »
Are you interested in 10" POLYMER Plates? see my post to Justin
Ali P;82037 wrote:And I would be interested too - I was after something similar before Christmas (and managed to persuade customer to allow me to do something else instead) but I would still be interested if, as Paul says, the blanks were not too costly and could be bought in small quantities. Probably for printing all over rather than just the middle. I read previous threads about plates where the conclusion was nobody wanted them, which is why the supply in the UK is limited!
