I'll add to that ...you might also have voltage problems.mrs maggot;66763 wrote:john, dont forget even in the states depending on which state you are in you have tax to pay of up to 28% on that price,
Fold ayay heat press
Re: Fold ayay heat press
Chromaluxe sheeting goes up to 40x60cm - would you not want a press big enough for that?
This would rule out the Hotronix and Adkins models already mentioned.
The Adkins Beta Maxi A2 would do it just, although a made to order model, with POA.
johnfrancis
Epson 7700 is a 24" (up to A1+) wide printer and takes 350ml capacity SubliJetE inks:johnfrancis;66935 wrote:What printer would you suggest to print 40x60cm........
http://www.sawgrasseurope.com/consumer- ... epson-7700
The Epson 4450/ 4880 will do A2+ and which would also be large enough, but cartridge capacity are smaller:
http://www.sawgrasseurope.com/consumer- ... tainium-uv
both of the above printers would also take large refillable cartridges, along with similar 9000 series Epson printers, so you wouldn't be ties to a sealed cartridges system. The 9000 series would then open you up to the option of using higher quality and better priced bulk inks compared to more domestic Sawgrass type inks.
