Blank Patches ?
logobear
Re: Blank Patches ?
Post by logobear »
It started for me when a good client wanted to logo a large number of fleeces, and didn't want embroidery .....
WE experimented, and learnt how to make our own badges, last months order was a little over £1500 !
The edging is the most time consuming aspect, I have learnt to lay the prints out in straight lines, and do as many as possible in a run on 2 sides, finally cutting them out into singles to do the other 2 edges. It is a noisy operation, get headphones !
Earl Smith
Re: Blank Patches ?
Post by Earl Smith »
Is it noisier than running embroidery machines 8 hours a day?
WorthDoingRight
Re: Blank Patches ?
Post by WorthDoingRight »
logobear;57636 wrote:It started for me when a good client wanted to logo a large number of fleeces, and didn't want embroidery .....
Do I assume from this that you sublimated the logo onto polyester and then edged them with your overlocker to create your badges and that you then 'glued' them in place?
mrs maggot
Re: Blank Patches ?
Post by mrs maggot »
WDR I print patches now, lots of them, and i import a few hundred embroidered ones every year as well, but the number of pre-made patch shapes seem to be decreasing everytime i want to order, so i guess in the end the make them yourself side will win out -
GoldRapt
Has thanked: 7 times
Re: Blank Patches ?
Post by GoldRapt »
Pictures for those that don't understand would be nice, I'm probably the only one who doesn't though :-)
regards
Tony
-launching july/august 2026
logobear
Re: Blank Patches ?
Post by logobear »
HI,
sorry, no pictures.
Yes - I buy 100% poliester fabric for about £10 a m (60" wide)
print on my sub badges, then stiffen with badge stiffener, then overlock the edges, cutting up as I edge
WorthDoingRight
Re: Blank Patches ?
mrs maggot;57650 wrote:WDR I print patches now, lots of them, and i import a few hundred embroidered ones every year as well, but the number of pre-made patch shapes seem to be decreasing everytime i want to order, so i guess in the end the make them yourself side will win out -
Thanks Laura, I can see this method of edging them yourselves would suit my type of embroidery machine work where I could hoop the basic material, embroider my design and then edge accurately.
WorthDoingRight
Re: Blank Patches ?
logobear;57664 wrote:HI,
sorry, no pictures.
Thanks for this information - much appreciated
WorthDoingRight
Re: Blank Patches ?
I would imagine that to make embroidered badges you could infact embroider a satin stitch border around your text or logo and then carefully cut around this edge. I would then turn the item over and remove as much stabiliser as possible. Finally I would paint the badge back with a thin layer of PVA adhesive to stiffen and seal it.
I will have to give this a go on my machine and see what the end result is like.
Earl Smith
Re: Blank Patches ?
To make my embroidered patches I buy Twilly from Gunold, its a denim weight cotton. Its 40cm wide and 10mtrs long. Costs 36€ plus tax. No backing is needed to embroider , its stable enough. Embroider name , logo or whatever and then a 3mm satin stitch around the border. In a jacket back frame I make as many patches as will fit in the frame. This is all digitised in my software. Then I cut them out and use a small burner to slightly burn the edges to stop them fraying. For the glue I use the special glue on a roll from Madiera. This is applied with a heat press being careful as its temp and time sensative.
Recent jobs are 400 name patches 8x3cm and 10 large patches 32x22. The big one took nearly 4 hours each to do.
