Does anyone use this thinner press and can anyone tell me if it does the 600ml aluminium bottle without a wrap and a decent anoutn around it.bigj2552;49101 wrote:you talking about here or abroad- i also had a look at corals one for doing my water bottles ect instead of buying another blanket, cause i cant be assed unscrewing all the dam screws every time i want to do water bottles ect.
http://www.coralgraph.com/heat-press1/m ... -certified
he used to market this press as an allrounder - he must have changed the blanket in it.....i,m sure PAUL(mod) has one of these(allrounder)
got to admit - having a serious sniff around abroad at the moment.....just sussing out the import duty/vat/delivery prices.......some of it looks rather tasty...esp the prices....but it is "bulk buying" except the machinary, which is single sales
What's in the box? Review will be forthcoming!
Re: What's in the box? Review will be forthcoming!
adding silicon sheet/pad - how much more do you raise temp/time by when using this method over the conventional mug settings ?Justin;49103 wrote:I thought about that one but it limits you to smaller items, you couldn't switch it over to mugs as a second press, which would be useful for larger orders.
I have one of these at the moment (As well as my Adkins mug press) all be it from BMS.
http://www.coralgraph.com/heat-press1/m ... machine-ce
I keep this one set=up for water bottles, just put a single 3mm thick silicone sheet in to pad it out, works a treat. These are the presses I'd like to get one or two more but hey ho, looks like I'll be shopping elsewhere!
