My very first Sublimation Print
JSR
Re: My very first Sublimation Print
Post by JSR »
bigj2552;45538 wrote:right guys....not so impressed with the mouse mats ...hmmmm
the colours dont seem to be coming out the same as whats printed on the paper....more kinda washed out looking...not rich in colour.....
[ATTACH=CONFIG]1000[/ATTACH][ATTACH=CONFIG]1001[/ATTACH][ATTACH=CONFIG]1002[/ATTACH]
first is ment to be bright red...printed out bright red.....second ment to be very black...its more kinda washed out black.....and the third.....well, its ok i suppose
any ideas ?
some will say - profile but, the mugs come out really good and true to colour on screen ect
taking with 5mp camera phone with flash ON !
That sounds partly like a profile issue (certainly that lack of a red, and most likely that black because what's printed isn't even a neutral grey).
You will probably get less "washed-out" results by using a high-release paper such as TexPrint (if you don't have any, press for longer with your low-release paper). That won't solve the wrong colours, but it might transfer more of the ink to give you a better transfer.
When I first got my B40W (an Epson), the results using Artanium ink with the Sawgrass profile were horrific. Everything had a yellow cast and the whole print looked "flat" (not washed out but with a distinct lack of "pop"). As soon as I had a profile made, the colours became accurate and the colours popped vibrantly.
bigj2552
Post by bigj2552 »
JSR;45539 wrote:That sounds partly like a profile issue (certainly that lack of a red, and most likely that black because what's printed isn't even a neutral grey).
Using Tru-Pix paper for everything at the moment jonathan......
Might need to order some Tex-print tomorrow from martin, just to see if it makes any differance...
the mats were done @ 60sec @ 190c..and i noticed the edge of the black was slightly kinda lighter colour....dunno if that was burnt or not enough ink applyed
off to try some iphone cases :tongue: - see how they turn out !
bigj2552
Post by bigj2552 »
can you get such a thing as a "dud sublimated mouse mat" ??
i just printed 2 earlier, and they never sublimated at all.....like nothing on them ?? :confused:
JSR
Post by JSR »
bigj2552;45542 wrote:can you get such a thing as a "dud sublimated mouse mat" ??
I suppose it's possible to have ones that don't have polyester on them, but I don't know who might sell them. Where did you get yours from?
I tend to print my mousemats for at least twice as long as everyone else (but then I seem to have to press everything of mine longer than everyone else does, so don't take my advice for gospel!).
TruPix should provide decent results so don't go spending too hastily (although I'm sure some TexPrint will benefit you later on).
bigj2552
Post by bigj2552 »
Got some mousemats from BMS & Coralgraph to try them both
The coral ones are the 2 that didnt print at all....and they come in bags ! :confused:
JSR
Post by JSR »
I normally use BMS ones. I did have a couple of samples from Coralgraph which printed up just fine (they were a little smaller than the BMS ones, but cheaper, although they were out of stock by the time I came to order so I went back to BMS).
Is it just me, or do mousemats generally look a little shoddy where they are cut from a larger sheet? Some don't have parallel edges, like they were cut on a Friday night after the pubs shut; while others have ragged edges as though someone's been hacking away with nail scissors. Maybe I'm just being picky.
bigj2552
Post by bigj2552 »
JSR;45545 wrote:I normally use BMS ones. I did have a couple of samples from Coralgraph which printed up just fine (they were a little smaller than the BMS ones, but cheaper, although they were out of stock by the time I came to order so I went back to BMS).
nope....its not just you bud........some look a little "shoddy", if thats the right word to use here, but nothing that would affect a sale tbh...
been at it since 10am....calling it time tonight....my eyes are bloody stinging.....
will prob see it in a differant light (excuse the pun) tomorrow
JSR
Post by JSR »
bigj2552;45547 wrote:nope....its not just you bud........some look a little "shoddy", if thats the right word to use here, but nothing that would affect a sale tbh...
Quite understand.
If it turns out there is something wrong with the Coralgraph mousemats, let them know ASAP. I'm sure they'll replace them for you.
only if something looks good on few item dont means all colors will look good. what profile you use at this moment??
bigj2552
Post by bigj2552 »
Paul;45550 wrote:only if something looks good on few item dont means all colors will look good. what profile you use at this moment??
morning paul...
using the stock one that came with coraldraw x5 - adobe RGB 1998 and the rgb colour pallet
