horizontal lines help
chongsta
Re: horizontal lines help
Post by chongsta »
thats fatal mate! time for a new printer!
goto ebay for an epson1290 > cheap to pick up and does a good job. then goto citylinkexpress for a CISS system > £40 > then see Paul for a colour profile.
All done for less than £100 all in.
gorgall2
Post by gorgall2 »
unfortunately I would also have to buy ink as the ricoh cartridges would not be any use.
John G
Post by John G »
Hi Gordon,
Not sure if this is any help but it may be a saving - the link below is for a 5550n which isn't compatible with powerdriver but you could get Paul to make you a profile.
http://www.ebay.co.uk/itm/Ricoh-GX-e5550N-Workgroup-Network-GEL-Colour-Laser-Printer-/140702872265?pt=UK_CamerasPhoto_Printers_Printers_JN&hash=item20c28b72c9#ht_1419wt_906
I would check that your carts fit and if they do you'll be able to use them instead of wasting them.
gorgall2
Post by gorgall2 »
Thanks John but the cartridges are not compatible.
Cheers Gordon
John G
Post by John G »
Are you sure - shame, thought that the carts would fit straight in the 5550n.
How much ink is left in the carts?
gorgall2
Post by gorgall2 »
Just double checked, definitely a no go.
1/2 black 1/2 yellow, nearly full magenta very litle cyan
gorgall2
Post by gorgall2 »
Thanks to everybody for their help and suggestions. The problem was terminal, but thanks to my friends new printer is on its way
Cheers Gordon
gorgall2;41957 wrote:Thanks to everybody for their help and suggestions. The problem was terminal, but thanks to my friends new printer is on its way
Cheers Gordon
Glad this is now all resolved for you and also thanks to Sawgrass for the upgrade support option provided on this even though the printer was originally bought in 2009/2010 and well out of warranty. I know a lot of people on here lambast Sawgrass, but I think they came through on this.
gorgall2
Post by gorgall2 »
Certainly a thums up for Sawgrass and indeed to you Martin
