Hi
Take a minute to introduce yourself. We won't bite!
John G
Re: Hi
Post by John G »
Oh! - Its a virtual prize - if that's the case, count me out :wink:
Daniel
Re: Hi
Post by Daniel »
Officialy counted out John :)
Ricoh Specialist - Midwich Ltd
Daniel
Re: Hi
Post by Daniel »
You are excused, just dont let it happen again :wink:
Dan
Re: Hi
Daniel;40704 wrote:Ricoh do not manufacture or supply any sublimation inks and to my knowledge do not intend to. Ricoh have the same stance on sublimation inks as other manufacturers, if a Ricoh machine fails while 3rd party consumables are being used Ricoh will look at the printer and determine the cause of faliure. If associated with 3rd party inks Ricoh will not hold any responsability.
I am not asking about this as i already know that :)
Daniel;40704 wrote:if a Ricoh machine fails while 3rd party consumables are being used Ricoh will look at the printer and determine the cause of faliure. If associated with 3rd party inks Ricoh will not hold any responsability.
thanks for this. this mean ricoh does not support sublimation ink then :cool:
Ian M
Re: Hi
Post by Ian M »
Hi Dan :biggrin:
Just a quick question Dan if I may. Has Ricoh ever considered producing something similar to the old Alps printers where you can print white or metallics to produce water slide decals etc? The reason I ask is that now something like the old Alps could be very popular.
Re: Hi
Hi Dan and welcome to the forum :-)
DSF Admin
Re: Hi
Welcome Dan, instead of phoning you now I can communicate via the forum as well!
Complete Mug
Re: Hi
Post by Complete Mug »
Hi and welcome Daniel
Are you thinking what I'm thinking that I think that you're thinking I'm thinking because if you think that I think what I think I'm thinking then we've got a problem?
