You could use Letter size TruPix. Some suppliers still sell it, such as: http://www.listawoodtradesupplies.com/i ... id=&pgnum=. It's a little more expensive, but it might be worth you trying it out.TPM;28007 wrote:Mine is a Ricog 3300 so I dont think it does borderless...?
Printing a low-res image...
Re: Printing a low-res image...
Thats a great idea - if it will let me print 3 per sheet - and its actually a bit less than BMS standard size
It depends how big you print, but you should be okay for 3 per sheet (I always did 3 per sheet, but then I don't do top-to-bottom printing).TPM;28058 wrote:Thats a great idea - if it will let me print 3 per sheet - and its actually a bit less than BMS standard size
Letter paper is a little shorter than A4 (11" rather than 11.7") and little wider (8.5" rather than 8.26") - the longer length of A4 is great, but the narrower width isn't, which is why I say it'd be great if suppliers would stock Legal size (that's 8.5" wide by 14" long) but they won't do that because it'd be too expensive.
...just to check....if I want to increase the size of this low res image from approx 8cm x 3cm - to a proportioned wrap I assume I need a high res image because the quality will suffer...? I have tried to increase it does go crappy (to use a technical term!)
If your mug wrap is typically 8"x3" (20.3cm x 7.6cm) then you'll be enlarging your 8cm x 3cm (3.1"x1.2") image by a factor of 2.54.
If you increase the size of the image by a factor of 2.54, then you're decreasing the dpi by a factor of 2.54.
So, if your image was 92dpi at 8cm x 3cm, then it'll be 36dpi at 8"x3". That's pretty low-res (hence the "crappiness" of the result).
If your image was saved as a JPG then chances are there's also a quality loss because people rarely set minimum compression on JPG, so that'll make things even worse.
Thanks for that JSR
Its good to try to understand the mechanics of these things!
Personally, I print using Qimage. I tell it what size I want, and it tells me what the dpi* would be. It uses certain algorithms in printing to improve the print whenever possible (although it can't work miracles).TPM;28302 wrote:Thanks for that JSRIts good to try to understand the mechanics of these things!
*Actually it talks in PPI, but the discussion of dpi vs ppi is probably a bigger discussion than you'd want to get into right now.
Not heard of that - is it free? I know pixels per inch and dots per inch
but you're right, I fear my head is set to 'colour pop' itself!
No, Qimage is available from: http://www.ddisoftware.com/qimage-u/features.htm
It used to be available in three versions from $35 to $80 (about £20 to £50 at the time) with all updates free. Those versions are still available but the version they're working on these days is a single price with an additional price for yearly updates. I'm using the old "Studio" version and have been for years.
It's not a graphics app, it's a printing app, although you can do the usual levels/colour tweaks prior to printing (Qimage uses filter files for these so the original image is never altered).
Users browsing this forum: Semrush [Bot] and 4 guests
