Uhm, I can see the colour and detail no problem on screen, just when it's printed I lose it. I have to lift brightness control up +60 in PShop to get any discernible difference on screen.Paul;47123 wrote:try bright the image up for about 10-20%
dsf mug for everyone
Re: dsf mug for everyone
i can see the crease's in trousers no problem justin in photoshop - without touching any brightness prior to print stage - the trousers are a dark blue anyway - are they not ?Justin;47128 wrote:Uhm, I can see the colour and detail no problem on screen, just when it's printed I lose it. I have to lift brightness control up +60 in PShop to get any discernible difference on screen.
No problem on screen it's when I print I lose the detail, must be a print issue but seems strange.
time to calibrate screens ppl
Looks like you have them set on to bright...
Did you calibrated with munki buddy? or still using my profiles?
I noticed when calibrating with munki Color are great but if profiled on metal then it need to brighten up a bit. dont know why but is just little bit to dark and contrasty. Color still great tho.
I had best results when used xpress old tee
with munki. need to add bit more contrast sometimes but this is better then to contrasty
try it. i think you will like it that way... Have and scrap tee?
Yeah, did mine on vapor tees. Any chance you could email full size pic of this Paul?
