bms;20685 wrote:You'll need the DF14 if you want to do latte mugs. The DF1 will do full top to bottom.
Can you buy the additional blankets for the DF1 as the DF14 makes the package £400 more expensive
logobear;20689 wrote:Great, you have chosen the excellent rhico option, now it is mug press dilemma!!!
Bread and butter is big standard 10 or 11 oz mugs, the minis and china and slanted cups are nice but each is an extra blanket at about £65 each. If you think these options are important to your business growth then makesure you choose a mug press that can take options. Soz but cannot advise here, but the £400 prize mug press from the lottery compmseemed to do it all. Suggest you up to £600 and get the best straight away, nothing wors than waisted time AND materials. Don't Buy Cheap....
IMHO
dj_doubler;20688 wrote:Can you buy the additional blankets for the DF1 as the DF14 makes the package £400 more expensive
bms;20698 wrote:You can buy replacement standard blankets and additional thicker blankets for the DF1 but the latte blankets won't be suitable in the DF1 as the DF14 is slightly different to take these blankets in addition to the DF1
Yes it is.dj_doubler;20715 wrote:Is the DF12 just the DF1 with extra blanket? as this is the one I will most likely be looking to buy....
bms;20718 wrote:Yes it is.
p.s @bms can you also do the money boxes with the DF1 or again do you need the more expensive one?
