Vinyl Suppliers List
Re: Vinyl Suppliers List
You could always try http://www.grafityp.co.uk/
They have loads of vinyl and flex for garments and signage. All Siser stuff which from what I understand is pretty good
- newsgroupmonkey
Hello all. I'm new here and looking for suppliers (other than fleabay which might be an option)
I've been reading the forum for a while (and registered today)
Just so I can get my head around (I'm new to vinyl), I think I'm working as follows:
BMS - http://www.printerowners.co.uk/
MDP - http://www.mdpsupplies.co.uk/
The Magic Touch (TMT) - http://www.themagictouch.co.uk/
BTC - http://www.btcactivewear.co.uk
Xpres - http://www.xpres.co.uk
The Transfer Press - http://www.thetransferpress.co.uk/
GrafityP http://www.grafityp.co.uk/
and another one someone mentioned in another thread... .the Vinyl Corporation - http://www.thevinylcorporation.co.uk
Is that everyone? Any other suppliers anyone might like to mention?
And I take it everyone recommends Flex? Or should I be looking at the flock type products?
I'm looking at (this moment) white on black and black on white.
I'm learning. So I'm probably spouting rubbish. Be patient :wink:
- mrs maggot
if there is a supplier near you (TMT) perhaps, then arrange to go and visit them - having a local supplier if you are lucky enough to is worth its weight in gold, should you ever run short - dont try and get your fingers stuck in too many pies, most companies vinyl is so close/the same, there are a few exceptions 123 from TMT for instance. But an hour spent in the company of a local supplier will be hours saved in the future.
- newsgroupmonkey
TMT are indeed need me (about 6 miles away).
Sounds like a winner then. Didn't realise they had an on-site presence too.
- mrs maggot
yes they have a real door you can walk through and everything :biggrin:, just make sure you call them first to arrange a visit, they also hold demo days etc. MDP do as well, and most of the others, but sometimes its down to locality
Have just received my Cameo, been looking at getting 12" heat vinyl, could anyone point me in the right direction please?
Many Thanks
Many Thanks
Hi DANNYD , where do you buy your vinyl for your Cameo ..???...I am bit lost in here as Cameo can have 12 " max most of the rolls are 50 cm ...DANNYD;99621 wrote:Have just received my Cameo, been looking at getting 12" heat vinyl, could anyone point me in the right direction please?
Many Thanks
Dave271069
MDP supply vinyl for cameo in sheets 12" x 20"Ravisteam;100787 wrote:Hi DANNYD , where do you buy your vinyl for your Cameo ..???...I am bit lost in here as Cameo can have 12 " max most of the rolls are 50 cm ...
Thanks Dave271069...They work out cheaper to Yolo ones and also MDP is a favourite one of many here isnt it..??
