Any help with t-shirts??
Re: Any help with t-shirts??
The JPSS paper for inkjet printer would be fine for hen party tshirts and the print lasts which isn't really needed for hen party shirts as they're usually only worn once.
Jpss can be printed using any ink . (I tried even on sub ink results good)..advantage is you can use cheaper cotton Tees specially on u r case for Hen night party stuff you can do the job cheaper but better quality and cotton tees are better than poly tees to wear. ..Pinksmiler;107821 wrote:I've just ordered a sample pack of jet pro soft stretch paper, I'm presuming u use it as a normal print out for sublimation? Is this what you meant ravisteam?
Sent from my GT-N7105 using Tapatalk
Trust me you won't be disappointed with jpss (white tees) ..If you want to print on a dark colour go for 3g opaque (no need to mirror and read the instructions )..just get yolo sample pack and try u r self...sub ink is okay too as I tried on sub link but washability might be not so good ..but hen night is just one off right ??Ravisteam;107858 wrote:Jpss can be printed using any ink . (I tried even on sub ink results good)..advantage is you can use cheaper cotton Tees specially on u r case for Hen night party stuff you can do the job cheaper but better quality and cotton tees are better than poly tees to wear. ..
Pinksmiler
Sounds good but what is 3G opaque??? This customer wants black Tshirts so using JPSS on a normal ink jet would be ok yeah?
Pinksmiler
Best place for tees then??? I've ordered the JPSS, just waiting for postie lol
Pinksmiler
3G opaque for black tees....u can't do sub in the black tees in the 1st place so the option is trasfers and yolo is good to buy transfers...
Pinksmiler
I've ordered my tees and the transfers, thanks to everyone that helped me make decisions, it's really appreciated.
Pinksmiler
I've done my design, looks good. But on the instructions for the transfers, it says to cut round the text? There are 4 lines of text so do I have to separate them all? If I put it on in a whole sheet will it show a background or clear stuff?
I assume you don't have a cutter ..so the best option I think is to print with a back ground color ..ex red back ground white text some thing like that...Otherwise it's a hard work as you will have to cut the white back ground out...Other option is to print a big out line to the text so text would be more visible and you can cut easily. ..also you can print the colour of your tshirt (won't be a perfect match )....what ever it is do a nice design that won't harm the visibility of the text and your customers would love them....However best option is vinyls for text but you need a cutter....
