what can you recommend
ASO Embroidery
Re: what can you recommend
Post by ASO Embroidery »
sorry Justin me being a bit of a idiot with regards file uploads hopefully that's it sorted now
Has thanked: 11 times
Haha :-) Yes, this is the same. The Bag Press fits perfectly along each side and is bolted through. I can see how this would work well for all the different presses as in the pic. Quite a straight forward design and for someone who can weld wouldn't be too tricky. Just needs to be spot on from a level point of view!
Developit
Post by Developit »
Thanks jennywren it's all go unpacking and setting up at the moment.
I would think that any press stand that takes the weight of your press and dimensions could be modified with holes drilled in plate or even a bigger plate.
