Paper Quality???
AlanD
Re: Paper Quality???
Post by AlanD »
forgot to mention, if you use Draw use the 'print preview' option this will show you if it will print properly and is also useful for doing step and repeat either with single or multiple pages in Draw. Saves faffing about positioning prints manually
Themugbox
Post by Themugbox »
Great news! My TexPrint R paper has arrived and I am again cooking on gas. I still however cant for the hell of me figure out how to get my printer to print onto the cut down paper.
To prevent me from throwing it out of the window, I have settled with printing 1 mug on the top then turning it round and printing the 2nd on the other end. This way I am getting 2 mugs out of 1 sheet rather than just 1.
I will try again once I have cleared a few orders.
Thanks again!
what is the exact problem with cut down paper?
Themugbox
Post by Themugbox »
The problem is getting the link between PS2014 and the Powerdriver to accept the orientation. I have created my own paper size inside the driver but can only get it to print in landscape which is no good to me as my paper tray stoppers will only facilitate me putting in my cut down paper short end first.
you need to place your paper long side first :)
like you would A4. This is opposite then in epson where you put paper vertical. ricoh you pot it horizontal. then it will print in landscape and correctly. hope this is what you need :)
Themugbox
Post by Themugbox »
The problem I have when I put it in longside first is that my paper stop in the feed tray doesn't go all the way forward to hold the paper in place.
JMugs
Has thanked: 13 times
Been thanked: 13 times
Post by JMugs »
Themugbox;97879 wrote:The problem I have when I put it in longside first is that my paper stop in the feed tray doesn't go all the way forward to hold the paper in place.
You are correct hence just change your orientation either in the printer or in your programme.
AlanD
Post by AlanD »
Paul;97876 wrote:you need to place your paper long side first :)
I use a Ricoh (A4 version) and cut down paper is put in portrait (short edge first) with side stops moved to suit
