Bms own coasters....
technick
Re: Bms own coasters....
Post by technick »
Doing this method with approx 1500-2000 coasters a week. It's a lot of work but there is no other solution. Whenever you find jigs that work 100% consistently give me a shout - so far i have had several built with no joy.
Tubstar
Post by Tubstar »
technick;128320 wrote:Doing this method with approx 1500-2000 coasters a week. It's a lot of work but there is no other solution. Whenever you find jigs that work 100% consistently give me a shout - so far i have had several built with no joy.
Would you be willing to share the specs of what didn't work. Would save us some work finding out what you already know ;-)
Alex.
technick
Post by technick »
I found that i couldn't get even pressure across the handmade jigs - there was always one coaster which had uneven pressure. Anything made with MDF i would avoid as it will cave in or reshape over time (think steel / metal would be the way to go).
It may also be a good idea not to have a bottom part to the jig for the coasters to sit in, and for the jig to be lower than the depth of the coasters, this means that the jig will not touch the top platen and the coasters will touch the bottom pad of the heat press. To load the coasters into the jig for this, you would need a flat sheet of some sort that will allow you to slide the jig onto the heat press.
If anyone has a successful jig system in place i would love to hear more about your designers - i would need 8 of them in total as due to expand into the new year.
I am more than happy to send you over anyone an illustrator file with a list of axis points for an A4 jig.
Tubstar;128319 wrote:This thread seems to be a bit heated (might be a heat press pun there somewhere)
I don't think anyone is really accusing or thinking others are lying or making light of the situation. I think we all want to find a solution and lets hope we do.
I replied to the other jig thread regarding developing one. It would be good to get something sorted... Something we all can work on and get results from. I think that's really what sites like this are about, and if not maybe they should be.
Alex.
I, too have posted a possible solution in the other thread Alex.
Tubstar
Post by Tubstar »
technick;128322 wrote: It may also be a good idea not to have a bottom part to the jig for the coasters to sit in, and for the jig to be lower than the depth of the coasters, this means that the jig will not touch the top platen and the coasters will touch the bottom pad of the heat press. To load the coasters into the jig for this, you would need a flat sheet of some sort that will allow you to slide the jig onto the heat press.
That's was what I was thinking after the experience with the Xpres purchased one.
Alex.
technick
Post by technick »
It would literally be a shell - like a 6 pack of beer plastic ringpull :)
bigj2552
Post by bigj2552 »
thought someone was in talks with sublimetal about this ?
would not mind chipin in decent amount for 3/4 jigs..let me know please who want to take this further ;)
bigj2552
Post by bigj2552 »
looks like it back to either bms own make or unisub coasters for our xmas stock
souljuice guy only has around 1000 left...i cant work with that, as we are staying open this yr right through xmas and new yr, and stock will need replenished after xmas day is over - will need to put up with what we got till we get some sort of work around ;(
Andrew
Post by Andrew »
bigj2552;128305 wrote:do yer self a favour wee man...jog on
Aren't you the precious one.
Andrew
Post by Andrew »
For the others, you get ready made jigs with the hardboard type coasters which pop out of the A4 sheet. These are supplied as a full A4 set as standard. Might be a quick solution even if it takes a bit of adapting. Have some in work but going in later so will check out if I have a chance.
As for tape marks being left. The right masking tape doesn't do it unless left to cool too much. Problem is, sourcing that masking tape is becoming harder. Trial and error from your local suppliers if often needed as the sticky residue is left with many.
Thirdly, the black backed coasters about do not have a raw finish. These will not have this problem at all but pose a different issue. The white print area is fragile and easily chipped when removing the plastic coating. Need to adapt a technique such as using tape to remove it. Nothing is ever easy.
