Profile for Epson D120
Ian M
Re: Profile for Epson D120
Post by Ian M »
leethesign wrote:I've only got a D21 Epson
I've been using an Epson S21 for the last couple of months with really good results. I decided to try using the Epson D88 ICC profile & I'm also using Corel Draw 12 & it all works fine. The inks I use are supplied by my friends in Australia & they are Ink Tec inks.
The colours I get are the colours on the screen each & everytime. All my customers are very happy & some of them are photographers who would be the first to complain if the colours were wrong.
It works for me so don't see why it shouldn't work for others. Hope it helps you out.
Ian
leethesign
Post by leethesign »
Hi Ian,
Thanks for that - where did you get the profile?
Lee
Ian M
Post by Ian M »
leethesign wrote:where did you get the profile?
Hi Lee,
I got it from Signal Ink Jet a long, long time ago when I bought my first batch of sublimation cartridges from them.
Might be an idea to ask Martin from BMS if he has a copy he could email to you.
Ian
If you pm me your email address then I'll forward it to you.
Ian M
Post by Ian M »
Thanks Martin ;)
Ian
I useto used 3rd party ink and profile and all works fine. what on screen was on the mug. never had a complain yet.
leethesign
Yes Paul - I think my problem is having no profile. Martin kindly sent me the D88 profile, but I can't install it - XP doesn't seem to support IMS files.
We'll keep on trying though, 'cause I reckon my color p'roblems will be solved with a profile.
Lee
it will accept it but u just can not click on it twice to install it. you need to manualy copy it to catalogue in windows. need find catologue profiled or something... dont remember as i have vista.
Lee - have you used an ICC profile before? Sorry but I thought you were already using something so I assumed (yes we all know what ASSUME stands for ;) ) you had all the other instructions. I'll forward the full set of pdf's including how to manually copy the file to the appropriate directory tomorrow (as I don't have the CD at home) unless someone beats me to it...
leethesign
Thanks Martin - I'm a bit of a technophobe - didn't even know what an ICC profile was u7ntil recently as I've never had to use one before!
I appreciate your help - and all the others on this forum. It's a really friendly place with loads of help available from nice peoples!!!
