Re: contour cutting mh refine 721
Posted: 02 Jun 2014, 00:04
Hi i've done a little scree record of it all.Paul;88844 wrote:if you used rip and print option you will have small window pop up. is called job menagerie or something like that
there should be your printer and cutter set up there. after hitting rip and print both, printer and cutter will have this same job. printer will have all image with reg marks and cutter will have outline job. you need to click on cutter and then "send"
it's already printed and sat waiting in the plotter with a pen in it at the moment just trying to draw around it. so i didnt "send" the print job. but when sending the cut theres no where I get asked to align the reg marks or anything
http://youtu.be/QlPHHOYeqNU[/video]
