contour cutting mh refine 721
Frostee
Re: contour cutting mh refine 721
Post by Frostee »
Paul;88844 wrote:if you used rip and print option you will have small window pop up. is called job menagerie or something like that :)
there should be your printer and cutter set up there. after hitting rip and print both, printer and cutter will have this same job. printer will have all image with reg marks and cutter will have outline job. you need to click on cutter and then "send"
Hi i've done a little scree record of it all.
it's already printed and sat waiting in the plotter with a pen in it at the moment just trying to draw around it. so i didnt "send" the print job. but when sending the cut theres no where I get asked to align the reg marks or anything
http://youtu.be/QlPHHOYeqNU[/video]
Graphtec CE6000-60, Sefa Rotex Pro Auto Open Swing, Galaxy Mug Press Pro, Epson P800 with sublimation inks, Ryonet Screen print setup
What reg marks you use? Sorry iam on my phone and cant see it
Frostee
Post by Frostee »
The 4 corner ones.
Frostee
Post by Frostee »
Frostee;88851 wrote:The 4 corner ones.
Sorry to bump. Hoping you might have an answer as I'm still stumped :-(
