dark garment transfers quote required
Dave271069
Re: dark garment transfers quote required
Post by Dave271069 »
I Would defo go down the versacamm route,
purpledragon
Post by purpledragon »
you are probably right dave ive just spoke to rogerc (cracking bloke nice to talk to him) so we''ll see where it goes from there at this stage its only for a quote i have to give
Ali P
Post by Ali P »
Has anyone tried the application sheets you can use over the top of dark transfer paper so that you can contour cut and weed around the design, add the top sheet, then lift it away from the backing paper before pressing - it works in a similar way to application mask on vehicle sign writing vinyl (but I am not explaining it very well)! It may be an option for Purpledragon if you only need a few prints...yolo have one that is for use with their dark transfer paper. Just a thought :)
All depends :-) Some things the VS can not do and you need the OKI White but then there are other things the VS can do which the OKI would struggle with.
Also, Brett, TMT WOW paper used to be a royal pain in the neck and very finicky. But their new stuff I have been using through the white printer is working very well.
