Mugs from Signzworld.. epic!
Mugman71
Re: Mugs from Signzworld.. epic!
Post by Mugman71 »
I have never dipped, just naturally cooled them, look fine to me, 2000 mugs later!
FutureProject
Post by FutureProject »
Been getting mugs from signzworld and so far (60 mugs in) not had a problem doing 175c for 170s with visisub inks.
Oneumbrella
Post by Oneumbrella »
does anyone have a link to a good supplier of mugs?
Benn81
Post by Benn81 »
Oneumbrella;81316 wrote:does anyone have a link to a good supplier of mugs?
After using many companies mugs i have found BMS supply the best mugs for me, I can't fault them. Each mug in the box is wrapped in bubble wrap aswell. Why not try some of the trusted suppliers. Bms, transferpress, longforte, xpres etc.
Signzworld have a shocking reputation it seems from a little web searching
As for cooling, I dunk in hot water, if i don't the image will bleed. I work in a small office space that turns into a sauna by midday with all the machines on. I make sure the mugs are at room temperature at least before pressing to prevent shock to the ceramic.
Become a full member of the forum and you will get discounts from suppliers aswell. :biggrin:
Cheers
Benn
