Problems with mugs print
A11kns
Re: Problems with mugs print
Post by A11kns »
just done a test print and still getting it... a little black ink on sponge in printer... but not much..
my print
the mug
almost like a spray of ink.. water... I don't know :frown:
Try getting the printer to push a few sheets of plain paper through without printing anything, you'll soon see if the tracks are causing a problem but it should clear.
purpledragon
Post by purpledragon »
Guessing your using something like a 1400 printer i used to get the same lines on the roller in the printer are little cog like things which feed the paper out i used to use coljet paper great paper but the ink stayed wet on it to long. As the roller goes over the wet ink it picks up wet ink and deposits it on the next print i cured it by changing paper to trupix
gorgall2
Post by gorgall2 »
Does your printer have an adjustment for the height of the printhead( small lever)? If it does set it to the higher setting.
A11kns
Post by A11kns »
it does it all on its own.. I have a epson sx218
purpledragon
A11kns;76156 wrote:it does it all on its own.. I have a epson sx218
what paper are you using
A11kns
Post by A11kns »
I'm not sure, it's in a plain packaging that came with my kit. It's strange how its been fine and now it's doing this?!?
purpledragon
get yourself a pack of trupix im betting this will solve the problem
A11kns
Post by A11kns »
Ok cool... Can you recommend a outlet at a good price?
Users browsing this forum: Semrush [Bot] and 5 guests
