so if there is no difference then i am always on cider
Making sure your tshirt is square and the image is in the middle - how do you do it?
Re: Making sure your tshirt is square and the image is in the middle - how do you do it?
with cider or not, i always screw up positioning on tee
I see some of the newer heat presses are fitted with a laser guide now for accurate placements.
- mrs maggot
i saw some of those at the show and thought you can make a stand alone one yourself using a laser pen and a stand - 99p shop will be the place to go
[ATTACH=CONFIG]1922[/ATTACH]
Thank-you all for your informative replies, I have come up with this idea of using a flat piece of wood (b&q £1.19) and have measured in the middle the width of a a4 portrait sheet and then marked ruler measurements in 5mm increments from the middle out so when i line it up i can see when its in the middle without keep turning a normal round trying to measure it.
Regards
Dave
Regards
Dave
- vB_ID:1922
- image.jpg (95.24 KiB) Viewed 563 times
Regards
Dave[ATTACH=CONFIG]1923[/ATTACH]
Regards
- vB_ID:1923
- image.jpg (94.68 KiB) Viewed 563 times
top idea! i understand that length of the wood is of size of your press base?
Yes Paul, it is!!
Cheers
Dave
Cheers
Dave
Got these last week:
http://www.youtube.com/watch?v=2UqeEWzD0i0
and the logo it
http://www.youtube.com/watch?v=o5hrEYccaXQ
Pretty cool the logo it
and the logo it
- mrs maggot
i have to say i have a t square it, gathering dust and i will be selling it on, as i really cant see the use in it for me
the tee sq is not as handy as the logo it as we had a client that was fussy to say the least about placement and the logo it fitted the job.
