I took a set up when I did a three day event, but doubt if I would do all that just for a one day market though.
If you need Public Liability, the National Market Traders Fed include it in their membership fee, and it is recoginsed by all the market people etc.
I would be very interested in how it all goes as well.
James
Mains generator ..
Re: Mains generator ..
Good luck! Running a heat press off a generator is a tall order - the peak draw from a heating element is quite high much like starting a motor which is why soft starters were invented for motors to reduce the initial draw.Volusian;75678 wrote:yes ... i will be taking a laptop pc, Ricoh dye sub, t shirt press, mug press, roland sign cutter .. and not all working at once.
I worked out a 2.5kw sine wave generator should suffice ... but ill check with dealer before i purchase ..
We use a Kipor 2.6KVa to run a commercial embroidery machine and laptop at shows and it works a treat
[CENTER]
