Cutter Help
Has thanked: 13 times
Been thanked: 12 times
Re: Cutter Help
This is a good point, also bear in mind the Cameo loads from the front and pushes out the back unlike larger cutters :-)
tlworkwear
Re: Cutter Help
Post by tlworkwear »
True and thats another thing which is not good for a long design lol.
Bex
Re: Cutter Help
Post by Bex »
I've cut a few 2 metre signs with no problems on my cameo. The only time the vinyl has slipped is when I've cut it down to 12" myself
bespokevans
Re: Cutter Help
Post by bespokevans »
Cheets guys...back to the drawing board then
bespokevans
Re: Cutter Help
What cutter did you go with TLworkwear?
mrs maggot
Re: Cutter Help
Post by mrs maggot »
tl, they are 30cm (300mm) not 3Mtr designs so i cannot see why he would have an issue with them ? on any cutter.
tlworkwear
Re: Cutter Help
mrs maggot;75436 wrote:tl, they are 30cm (300mm) not 3Mtr designs so i cannot see why he would have an issue with them ? on any cutter.
the OP said that they wanted to cut a 300mm x 3000mm design unless I read it wrong.. I'm on mine ipad and can't be bothered to go back a page lol but will check later. I'm sure it was a 3m design though..
@bespokevans I got a promacut PC720 which took me a while (and a lot of help!) to get working but it can cut up to 630mm and seems pretty good. Having some issues finding spare blades for it though as the manufacturers won't reply to my email lol.
Re: Cutter Help
I am as a person who doing metric for 33y now :) i can confirm 3000mm is 3meters :)
bespokevans
Re: Cutter Help
Haha sorry for the confusion...I was taking about 3 metres or 300cm or 3000mm :)
mrs maggot
Re: Cutter Help
my bad then, i must have read your original bit wrongly
