9 pin Cables for a Refine?
spongerobinson
Re: 9 pin Cables for a Refine?
Post by spongerobinson »
with regards to these 9 pin cables, i know for other computer uses, there are a couple of different wiring standards, so possibly your cable is the wrong wiring for your cutter? there are null modem, straight through, and maybe others i'm not aware of.
so if you get arko's cable again, and if there are removable connectors, it might be worth a quick look at the internal wiring of the cables to see if they are different.
arko
Post by arko »
Thats the problem though spongerobinson, my cables are sealed units.
s31teg
Post by s31teg »
You will probs need a 'null modem cable'
This is what is typically used for this type of application
Dave271069
Post by Dave271069 »
Hi ian.
Just loaded coral draw and signblazer on to pc. So going to have a play. Is it possible to borrow cables today sometime.
Now where is the idiots guide to coral draw and signblazer. Do they work with each other or am I going down the wrong route?
Dave271069
http://www.ebay.co.uk/itm/180373885949? ... 1497.l2649
this is the one I purchased but not sure if it will work as I've bought similar before.
arko
Post by arko »
No problem Dave. Just ring the house number to see if anyone is in. I have told her where the cables are.
Dave271069
arko;75372 wrote:HAHAHAHA....... thanks for the get well wishes Social!
By the way Dave... did we try your cables on my cutter? I think we did and they worked didnt they?
if you remember they didnt work, or i would of swapped you ;-)
arko
Post by arko »
Dave271069;75405 wrote:if you remember they didnt work, or i would of swapped you ;-)
Hahaha... I dont remember... its my old brain doing overtime. :wink:
Dave271069
OK usb serial arrived and plotter still does NOT WORK....
After a bit of research i believe i need the RS-232_C but the few i have been buying are RS-232,
Does anyone know if this is correct, have i been buying the wrong ones does the -C MAKE A DIFFERENCE?
HELP
arko
Post by arko »
Not sure if it makes any difference Dave. But if you hurry, you can still catch the missus at home before she comes to visit me in hospital. The cables are hanging over the back of the cutter. under the cover.
