Turn 7in x 5in Photo in to a large Laminated Vinyl Print High Quality
Re: Turn 7in x 5in Photo in to a large Laminated Vinyl Print High Quality
I dont know what you mean smo ! *blushes at the thought* hahaha.... and that site is actually quite a fun way to produce large images with a different quality!
Well, the photo you post is 95dpi and badly pixelated.
I put it through PhotoZoom Pro2 and using the mathematical formula for pixelated photos I changed the print size to 4.5ins x aspect ratio and increased the dpi to 500.
This gave me a pixel dimension of 1600 x 1200 but its 2.8mb in size so I cant post it.
I also blew it up to 45' by aspect ratio, so it can be done but you would need to stand a few feet back for the eyes to focus.
Did you scan the original by any chance and if so what dpi setting did you give it please?
Hi Everyone. Thanks for all the advise, I had put up a low res copy just for reference. I was impressed with the Illustrator download , because the upload was low res the download will be relative. The Original photo is quite good so if I scan it at high res and the use either Perfect Resize or Illustrator, I think I can get near photo quality for a 7 foot x 5 foot wall print and not something that is best viewed from a distance. Any suggestion on the best Vinyl or medium to use . Regards Ian
The only failure, is the failure to try.
