gorgall2 ...I haven't heard of recycled pot coasters (sometimes I live under a rock) so I asked my friend google and along with some places to buy them in a set I also found this suggestion....not sure if you want to try it but I found it interesting
"another good one is to put yoghurt pots in the oven at a low temp, they start to collapse back into a disc (which is how they start off) with the graphics all compressed in a ring, if you then take it out and put a weight on it, you end up later with a yoghurt pot coaster. They make discs and print the graphics in a compressed ring then blow them into the finished shape!"
Have you had any success sublimating onto something other than standard blanks?
Re: Have you had any success sublimating onto something other than standard blanks?
Thanks, I might give it a try. The one I had was a square one that was made from shredded pots, there were even some flecks of the foil lids mixed in.[ATTACH=CONFIG]1781[/ATTACH]
- vB_ID:1781
- ypc.jpg (4.37 KiB) Viewed 217 times
gorgall2...would be interested to read/see your results if you do try it.
The picture you posted looks like the ones I saw for sale
