Page 2 of 2
Re: Does this remove vinyl from clothing?
Posted: 07 May 2013, 08:09
by tlworkwear
After saying that polish remover works a treat I had cause to remove some vinyl from a football shirt I had printed and I just can't seem to get the damn stuff off now!! Im using Magictouch Flex123 vinyl and it seems to be stuck on hard hahaha! Thats normally what I want but not this time! Will just have to try to find another way to fix the issue :/
Posted: 07 May 2013, 12:24
by mrs maggot
the 1,2,3 flex i have found hard to remove as well
Posted: 07 May 2013, 12:43
by logobear
YES, premium flex is easiest to remove, Paper and 123 don't shift...
Posted: 07 May 2013, 14:49
by tlworkwear
Yup I have found that out the hard way haha! Its both a good and bad thing I suppose cause at least I know that the vinyl isnt going anywhere once I have pressed it
Posted: 07 May 2013, 14:50
by tlworkwear
mrs maggot;71259 wrote:the 1,2,3 flex i have found hard to remove as well
did you manage to remove it? If so how?
Posted: 07 May 2013, 15:14
by mrs maggot
small bits yes, leave them go cold completly and then pick them off with a pin, if you use remover, put it on the back of the t shirt, and let it come through to the front
Posted: 07 May 2013, 20:22
by viccar
you need acetone-based nail polish remover.
Acetone removes glue.
We used it to clean glue off stuff when i worked in a glue factory.
