Does this remove vinyl from clothing?
tlworkwear
Re: Does this remove vinyl from clothing?
Post by tlworkwear »
After saying that polish remover works a treat I had cause to remove some vinyl from a football shirt I had printed and I just can't seem to get the damn stuff off now!! Im using Magictouch Flex123 vinyl and it seems to be stuck on hard hahaha! Thats normally what I want but not this time! Will just have to try to find another way to fix the issue :/
mrs maggot
Post by mrs maggot »
the 1,2,3 flex i have found hard to remove as well
logobear
Post by logobear »
YES, premium flex is easiest to remove, Paper and 123 don't shift...
tlworkwear
Yup I have found that out the hard way haha! Its both a good and bad thing I suppose cause at least I know that the vinyl isnt going anywhere once I have pressed it :)
tlworkwear
mrs maggot;71259 wrote:the 1,2,3 flex i have found hard to remove as well
did you manage to remove it? If so how?
mrs maggot
small bits yes, leave them go cold completly and then pick them off with a pin, if you use remover, put it on the back of the t shirt, and let it come through to the front
viccar
Post by viccar »
you need acetone-based nail polish remover.
Acetone removes glue.
We used it to clean glue off stuff when i worked in a glue factory.
