Re: Do I need teflon sheets?
Posted: 09 Jul 2010, 15:29
So, can I get this right, you place a sheet of greaseproof paper on the teflon bottom plate, then the t shirt on top, followed by the transfer paper dye sub ink print then a further greaseproof sheet before pressing down the top plate for the heat transfer? Is that correct, as I dont want to burn my mum's house down at my first attempt at t shirt printing. Try explaining that one to the fire investigation officer lol.
Also, can I ask about temperatures, if using a dye sub suitable t shirt with an A4 size colour paper transfer, what temp should I use and for how long? The G3838 heat press I bought is okay but the manual is in pidgeon German so pretty hopeless and no explanation of temps etc. Or, will the transfer paper I buy have an instruction sheet and temp guidances?
Remember: Every Day is a Good Day, some Days Just Come with Clouds!
