transfer tape leaving residue please help
John G
Re: transfer tape leaving residue please help
Post by John G »
Why are you using transfer tape for text?
soulclaimed
Post by soulclaimed »
So it stays in the correct layout as its standard aerial font with separated letters can anyone tell me how to get rid of the residue once its on the shirt?
You seem to have 2 similar threads running at the minute which won't help with responses.
Are you using vinyl lettering here? If so, is the material not sticky? If not, as previously mentioned you need wider application tape.
soulclaimed
I'm using 3g jet opaque transfer paper
John G
Post by John G »
Are you using the heat transfer mask from yolo as well.
logobear
Post by logobear »
stop using tape!
over 20 years printing Ts, never used it!
imho!!
mrs maggot
Post by mrs maggot »
let me try and understand to help the answers come in, you are using 3g jet opaque, then you are contour cutting around the individual letters, then you are using a heat tape to fix all the now weeded letters and then press them as a self made transfer ?
as John says what are you using and is it from yolo ?? there should not be any residue
soulclaimed
Mrs maggot you are correct but the one I got was from eBay I don't know if its a yolo one the sheets have no branding on
John G
Post by John G »
Well, there's your answer. :rolleyes:
If you're using yolo transfer sheets, buy their masks - then you'll know it works.
soulclaimed
I'm also thinking of getting into laser transfers for the self weeding aspect can anyone tell me a cheap laser printer that will do the job I don't require white ink
