NEwbie issues help lplease
marksbananas
Re: NEwbie issues help lplease
yeah didnt on first one lol spot the newbie,,,,,, Think i have been using paper upside down just going to press again and see, what time and heat recomened for them, i have been told anywhere from 15-30 seconds to 2 minutes
We press at 190 for 50 seconds at a medium-firm pressure using the ricoh and get brilliant results, let us know how you get on.
marksbananas
Cheers now i know that there is a good and bad side toapaper going to try again
the whiter side goes face down with tru pix and ricoh 3110 if thats any help
It almost looks like it's undercooked but your time and temp suggest otherwise. I don't use a Ricoh but from what I understand cooking times/temps are slightly less than Epsons and therefore blacks can turn brown with overcooking. ARe you sure your press is up to temp? Do you have any way of checking this? May be worth knocking it up a bit and see what happens. (Just in case it's under temp)
I always pre-heat phone inserts slightly before applying the transfer. Pressure wise I just rest the press on top so almost no pressure. Also, you can press these upside down so transfer paper down.
marksbananas
got it sorted i had the paper upside down.... d.oh did realise there was a good and a bad side. Thaznk you everyone!!!
powerdriver prints don't look as 'dynamic' as a normal photo print. The colours become more vibrant once the image is sub transferred onto the substrate.
marksbananas
One last question for now when you print for acrylic blocks what setting do you use on the powerdriver as there is not a setting for acrylic
