Can you use vinyl instead of an acetate to make an exposed screen?!?
Discuss anything to do with Screen Printing.
John G
Re: Can you use vinyl instead of an acetate to make an exposed screen?!?
Post by John G »
Yes you can use cut vinyl when exposing screens - you can use a number of things but I still use clear acetates printed with a laser printer.
I used to do work for a guy who supplied his own print ready artwork and that's what it was - black sign vinyl cut on a plotter and weeded. The end results weren't as good as a posi due to the plotter not cutting perfectly, and also the thickness of the vinyl effected the exposure - but it does work. For very short runs of plastisol you'll get away with applying the vinyl to the screen direct, no exposure needed.
ASTROID
Post by ASTROID »
yes you can ...... i had an issue with my printer not wanting to take the acetates correctly so i decided to cut out of black vinyl in reverse and attach the vinyl to a clear acetate then laid this on the screen covered with a sheet of glass placed under a 500w lamp at a height of 24inchs for 25mins and came out perfect i used a plotter to cut the image first.
John G
Post by John G »
Hi Astroid - this thread/post is over 4 years old - I think the OP may have the answer by now - lol.
ASTROID
Post by ASTROID »
i know but i was looking for the same answer which i could'nt find so i thought i would post so any one else wanting to try can without spending hrs looking on the net
John G
Post by John G »
Very good point - more info cannot be a bad thing.
Daninho
Post by Daninho »
I actually plan to use Vinyl as a stencil on a screen insteal of the UV coating, i think it can work with basic shapes like Fonts etc.. Just a cheap way of screen printing at home with water absed inks i would say.
