paper or silicon ?
Re: paper or silicon ?
Thanks guys great information and very helpfull i have orderd trupix cost comes into play in certain areas but iam not cutting corners as a newbie i want to reduce how much goes wrong thats my theory ha ha equipment is on its way so will have to wait and see
As above - no bleed with Trupix paper.
Not having to wrap a sheet of paper around it saves a lot of time on larger press runs and reduces the risk of a wrinkle in the paper affecting the pressing.
Mark
Mark
Agreed....never used any 'covering' on my mugs and never had bleed problems.socialgiraffe;62069 wrote:Use a decent paper like TRUPIX and then you should never get any bleed through.
I have not print with heat etc, because i don't know that process. But some time i have print my mug with hand paint. First i have drop design at poster then cut it and apply on mug. Then paint it without any doubt. I never face the problem like bleeding etc.
Edward
“I believe that it is better to tell the truth than a lie. I believe it is better to be free than to be a slave. And I believe it is better to know than to be ignorant.” - H.L. Mencken
Signage Melbourne
Signage Melbourne
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
