t-shirt transfer paper - contour cut with out optical eye.
Re: t-shirt transfer paper - contour cut with out optical eye.
Thanks guys. Contour cut software i us is FlexiStarter 10. I had older version, 8,5 but contour cut wasnot possible. I will make another video shortly about how to do it from a to z. And will try show properly how i allign knife to reg marks.
arko
Post by arko »
Well, I tried and miserably failed... good job I had my plotter pen in instead of a blade. Im using signgo pro... and dont seem to be able to set start points on markers.... any ideas? You made it look so easy Paul.... any chance of a more detailed camera shot of settings on your programme? Im sure print/cut settings all look similar on all these programmes. I tried print/cut (only works for Versacamm on my software), contour cut... unable to set 1st marker,... print... then I place d the image into my cutter,... clicked cutaround... but couldnt get the start point... had blue pen shapes everywhere except where I wanted it! :( boo hoo... now im really stuck.... any help Paul would be great! Thankyou.
Dave271069
Post by Dave271069 »
Hi arko. If its anything similar to a cameo i could pop over and help out.
arko
Post by arko »
Its a Ramtin 720 Dave. Easy enough to use as such but trying to setup contour cut is baffling. I will check SignGo website first to see if there are any tuts...... and please... call me Ian. :)
arko
Post by arko »
website keeps going up and down...
arko
Post by arko »
Finally managed to get a question off to them... lets hope they reply. :).... and still... great tut Paul! :)
sorry buddy but i dont know this software. I am not even sure it can contour cut. but if it does then it should have lot of different reg marks there to choice from as each company use different looking ones. for chinese cutters i would sugest to use same as mine. circles looking like a little targets. if you pick wrong reg marks then software wont cut it as it wont recognise proper machine in your system for those reg maks
arko
Post by arko »
It has 3 options for reg marks... 1. none.... 2. 2 corner.. or 3. Tri corner (Triangular). I will try and post a screen shot so that you can see it. ... btw... which software do you use for your videos?...Is it CamStudio? or something similar?... Videos look great and the zoom functions are good too! Thanks Paul.
I use HD camcorder. Cheap :) and screen records by quicktime.
5cr3w8all
Post by 5cr3w8all »
excellent video.......thanx Paul
