Subli Metal
Re: Subli Metal
Scapaflyer;59684 wrote:Can anyone suggest a cheap source for aluminium subli sheets with a white finish. I usually use BMS, but their website insists on trying to charge me £15 postage even though in the top corner it says delivery is £6.99.
£15 delivery is out of the question as I only want 15 sheets and can't think of anything else i need to order at the moment.
Cheers in advance for any help
Mick
The £6.99 +vat is the UK courier cost, but depending on postcodes this is fine tuned during checkout. If you are logged in then your postcode should be noted by our website and reflect the lowest delivery cost where ever you are in Europe or further afield. Unfortunately Parcelforce surcharge by 225% to the Highlands and Islands hence the higher costs.
Ian M
Re: Subli Metal
Post by Ian M »
Justin;59691 wrote: I guess you get punished the same as us for living on an island, all be it still UK we may as well be abroad! ....in the sunshine.
I thought it was more like living near Norway in the snow :wink:
