http://www.thetransferpress.co.uk/acatalog/KISSCUT_FAQ.html States here you CAN press onto Dark coloured clothing !!socialgiraffe;58270 wrote:Kisscut paper is not going to work, the same way laser transfer paper will not.
The logo is going onto a coloured garment so there needs to be a white base on the transfer or use vinyl which effectively blocks out the colour underneath.
If you image the red logo going to a green shirt for example, the red will mix with the green to create a completely different colour.
coloured cotton transfer help.
Dave Scott
Re: coloured cotton transfer help.
Dave Scott
Can I image to dark garments?
The KissCut process allows you to apply images and graphics to white, coloured and dark coloured garments using the full range of imaging and embellishing techniques available with the KissCut process.
Dave Scott
http://www.thetransferpress.co.uk/acatalog/KISSCUT_FAQ.html READ THESE FAQ'S.
Dave Scott
http://www.thetransferpress.co.uk/acata ... T_FAQ.html - *READ THIS*
Dave Scott
http://www.thetransferpress.co.uk/acata ... T_FAQ.html *READ THIS*
I did read that, but further down it states that it can not do full colour photographs.
It will probably do what Frazzle needs but to be honest, they have been very clever (as most suppliers are) in the images they have chosen and also the colour of garment.
Plus they are only good for 40 washes which I think is pretty low
- WorthDoingRight
Well if you are a biker that is probably a life times wear lolsocialgiraffe;58357 wrote:Plus they are only good for 40 washes which I think is pretty low
If on the other hand it was my wife then probably need a new one after a week or two!
- WorthDoingRight
I still cannot see what harm printing this using the transparent backed light t-shirt paper would cause. As the logo is pretty much a square then just cut around the outside of the square and hey presto! Significantly cheaper than dark or wow type papers also.
