Help Needed!!!
Re: Help Needed!!!
Not in th print head. You need cartridges there
- WorthDoingRight
Re: Help Needed!!!
No, the word 'filter' snuck into another thread! I have an OKI laser printer and tried the mugsnmore paper out, once I had found how to actually get it to feed without melting I got an image that following the guidelines washed straight back off the item lol I found that longer pressing and higher temperature was needed to get the transfer to stick to my substrate. The results however pushed me back to sublimating tiles instead as they just looked superior and I suspect would last a lot longer in daily use. I have not tried yolos laser transfer t-shirt paper but Paul is right in saying that the neenah papers are well regarded on most forums and I suspect this is probably down to not finding the 'sweet spot' for pressing.
