WOW mugs
Craig
Re: WOW mugs
Post by Craig »
socialgiraffe;55015 wrote:WOW = Waste Of Wonga
IMHO LOL!!!!
Quality lol
Russ
Re: WOW mugs
Post by Russ »
I used to get a similar mark on mug designs (std mugs not WOW mugs) where I was using as much of the paper as possible to put a solid colour on the mug, and then putting the tape horizontally (so it went over some of the back of the design).
Now I make sure its a small piece of tape and it's stuck on vertically not covering any of the design.
JSR
Re: WOW mugs
Post by JSR »
The coating does seem to be "soft" on colour-change mugs. I back the temperature right off and increase the time when I do them. You also want to be sure that you're using the polyimide heat tape, not the polyester stuff, but both react with the coating on colour-change mugs.
The residue does wash off, it's just tough to get it off at the edge of the paper without damaging the coating. For most mugs, I would use TruPix paper but I use TexPrint with colour-change mugs because even the paper seems to react with the coating (leaving it orange/brown, when the mug is white, where the paper is in contact with the mug during heating).
I stopped doing them awhile back because, no matter who I bought them from, they always seemed to be "C grade". The bottom ring of the mug (where it sits on the table) was invariably a right mess in at least 1/3rd of the mugs, and there would be blemishes or other marks only visible once the coating had turned transparent. I was rejecting more than I was selling, so I gave up doing them. When I tried to sell my "rejects" at knock-down prices, no one wanted them - so I know I did the right thing to stop doing them, otherwise I'd end up with a whole mess of dissatisfied customers.
These are a product that were infinitely better in the days of TAMS but, now, I wouldn't touch them unless a supplier could guarantee A-grade quality.
Re: WOW mugs
Can you believe i still have couple of tams here??? :)
I think is only two blue left but hey hooo. they are collectors items this days :cool:
WorthDoingRight
Re: WOW mugs
Post by WorthDoingRight »
JSR;55032 wrote:I stopped doing them awhile back because, no matter who I bought them from, they always seemed to be "C grade"
Makes me now wonder if they don't put the heat changing coating on 'unsaleable' normal mugs to hide the imperfections and get rid of them!
But this sort of quality reminds me of those pens you used to buy at the seaside where when you turned them over the ladies bathing costume disappeared.
quasar
Re: WOW mugs
Post by quasar »
Tried 150 for 200 seconds instead of 180 for 180 and it worked, also moved to black mugs and they are better then blue.
Thanks for all the suggestions
JSR
Re: WOW mugs
Post by JSR »
Paul;55036 wrote:Can you believe i still have couple of tams here??? :)
I think I have a red TAMS or two here. I may even have a blue one, and possibly even a gold or silver one (not WOW, obviously) with TAMS on the bottom.
