Cutter .. Cameo ?
Re: Cutter .. Cameo ?
The cameo can take up to a3 pre-cut, but if you can buy the full rolls and cut the vinyl to size if needed. As i am just practicing with vinyl (using card more for my photography) i cut the vinyl to size for whatever i am doing and if it is small enough stick it on the cutting mat (12" by 12"), saves all the faffing about changing the roller size
check out mdp - i got mine fro mthere http://www.mdpsupplies.co.uk/silhouette-cameo-packs.asp
getting 50cm rolls and cut them to a3 wide will save you £££
Cheers guys , All ordered , along with some 300mm Cameo sheets to have a play on , Anyone got any good trusted outlets online for buying the vinyl rolls for t-shirts printing ?
plenty of them depending on what your looking for - www.xpres.co.uk and www.mdpsupplies.co.uk are where i have seem the most options.
+1bassqee;48622 wrote:plenty of them depending on what your looking for - www.xpres.co.uk and www.mdpsupplies.co.uk are where i have seem the most options.
my main source of vinyl.
http://www.mdpsupplies.co.uk/mdpflex.as ... rentcat=83
Just watching some info on youtube there is so much you can do with those cameo's other than t-shirt vinyl so glad i ordered it now
I use CorelDraw to cut on my Craft Robo.
I would expect you can do the same with the Cameo with software such as Inkscape.
Mark
Mark
and how much is a 50cm roll of the stuff ?...or did you mean - 50meters rolls ?Paul;48616 wrote:getting 50cm rolls and cut them to a3 wide will save you £££
