Help with Jinka Goldcut JK series drivers
Re: Help with Jinka Goldcut JK series drivers
is windows recognizing your machine when usb cable is pluged?
roguechloe
Post by roguechloe »
when i plugged it in for the first time it said that it was loading the drivers and then came up with a box with goldcut series driver failed and a red cross, when i plug it in via usb, nothing happens and it doesnt show up in printers and devices or anywhere else.
Karen.
Post by Karen. »
I know this is a very old thread now, but I didn't want to start a new topic when there was already one here.
I have inherited a Goldcut JK721 cutter but it came with no drivers. After several days of trawling everywhere for drivers for it I am having no luck. Like the previous reply I can get that far and that's it.
Does anyone have a copy of the drivers they could possibly send me (message me and I will happily pay for them).
Scapaflyer
Post by Scapaflyer »
PM me your email address and I will send you a rar file of the driver disk
Branty
Post by Branty »
Is there any chance you could send it me too please. I'm really struggling to find a driver for mine.
decca591
Post by decca591 »
Hi Guys
I know its an oldish post but I am looking for a set of drivers for my trusty Goldcut 721. Built a garage to use as a workshop and has been running fine for last couple of years, problem with power and long story short brought it and my desktop home, back into office at back of house, had to change power supply, which got pc working again, but had to let it re-install windows - ended up with win 10, cant roll back as my pc was not working correctly so just need to go with win 10 for now, I now need drivers fir my goldcut - anyone out there got a disk or can copy and send file - will pay, just want to get back up and running !!
Decca
Mugshots
Post by Mugshots »
Hi Decca. Did you have any luck with this at all please?
decca591
Post by decca591 »
Mugshots;137302 wrote:Hi Decca. Did you have any luck with this at all please?
Hi Mugshots !!!
I did sort it out, the problem I was having was with windows not allowing me to install the drivers for the Goldcut, windows no longer allows unsigned drivers - as a safety feature, but if you are running older software or hardware there is a good chance they would not have been signed off by Windows - After much head scratching I found out that I could disable the windows signatures temporarily which allowed me to load my drivers, I installed everything then I ran Bellarc advisor which told me where my goldcut had been installed and I simply changed my signblazer settings accordingly.
I have also used refine and copam settings in the past as these are basically the same machines, you will be able to down load your required drivers from US cutters site !!!
I followed the instructions from "maketecheasy" to disable wins signature checking.
Long winded, apologies but hope it helps !
Decca.
