please please please can someone help me!
North guy
Re: please please please can someone help me!
Post by North guy »
yeah ricoh inks with rocoh printer.
i use this paper http://www.ebay.co.uk/itm/Visi-Jet-Subl ... 500wt_1180
mrs maggot
Post by mrs maggot »
but the two pictures are quite different one is a high density of black the other isnt, have you done other times with the mugs, or just the original times for the keep calm mug, the black ink always needs the most time, 180 and 180 would be better, and as others have said turn the mug
purpledragon
Post by purpledragon »
as sure as eggs is eggs its your press im guessing chinease entry level job unfortunatly nothing short of a new blanket will help and not even then of course i may be wrong
North guy
Post by North guy »
when i bake at 180 180 the black seems to go brown but its ok when i reduce, ive not tried turning the mug yet though, do i turn it hald way through the bake time?
this is the press i bought http://www.ebay.co.uk/itm/190638943782? ... 496wt_1163
mrs maggot
yes you turn it as described in the post before, dont stop and start the counter, just whip it out and turn it over - if you want to save mugs, cut the design in 2 and just press one side of the mug top to bottom, without turning, then press again, with turning and then you can compare
North guy
Post by North guy »
Success, almost lol
i have put the temp up to 180 again for 180 secs and turned it at 90 secs and it is alot better, a couple of corners fade just a tad but not much.
Cheers everyone ;-)
mrs maggot
glad to hear it
Earl Smith
Post by Earl Smith »
Which heat press are you using?? I have the same problem and have a sneaky suspicion that the heat element isnt wide enough.
John G
Post by John G »
Bubblegumweb, Please read the dates on the threads before you post - you seem to be resurrecting every single old thread on the forum :rolleyes: I suppose it gets your post count up :confused:
