Page 2 of 2
Re: mugs all crazing on the inside
Posted: 15 Feb 2012, 09:46
by JSR
You're not the only ones
. It's a lesson you don't want to learn too often when printing black/dark designs onto an El Grande.
Posted: 16 Feb 2012, 09:48
by Scotty@BMS
I like John's fan cooling method, but in the past when I have dunked the mugs I've used hot water (as in from the kettle hot added to a little cold) as opposed to just warm. No problems at all with that method. How many mugs are you down, Laura?
Posted: 16 Feb 2012, 10:39
by mrs maggot
we only ever use warm/hot water we did him 60 mugs, and there are 20 that he is not happy with, so i am about to do him 30 as a goodwill gesture and hopefully that will be sorted
Posted: 16 Feb 2012, 10:43
by Scotty@BMS
mrs maggot;39970 wrote:we only ever use warm/hot water we did him 60 mugs, and there are 20 that he is not happy with, so i am about to do him 30 as a goodwill gesture and hopefully that will be sorted
Remind me on your next order, I'll sort you out.
Posted: 16 Feb 2012, 10:44
by mrs maggot
thanks Scott, will be ordering soon
Posted: 25 Apr 2012, 10:24
by Dezignwar
Out of interest do you remove the print before you fan them / dunk them or do you leave print wrapped around the mug while it cools?
Sorry if this is a silly question, i havent had any problems with bleeding. just wondered i remove mine then dunk them in warm water just wanted to know if what i was doing was correct as i am self teaching. lol..
Posted: 25 Apr 2012, 10:33
by smitch6
yes remove the print the moment it comes out of the press, otherwise it would still be transferring,
what i do is raise a corner and make sure it's done right if it's faint i put it back in for 10 secs and check again
Posted: 25 Apr 2012, 10:55
by Dezignwar
That's how I do it.. Ya...
