New Start Printing
Re: New Start Printing
Are they RN mugs Justin? Been having trouble with cracking noises with the ones from LW.
Sharon
Sharon
I would think cracking noises are more to do with the ceramic mug rather than the coating. It might just have been a bad batch but if it persists I would swap mug supplier. Most pinging/cracking noises might not result in to many problems but if it happens often then you will get the odd one with leaks through hairline cracks when hot water is poured in and expansion takes place. All this I say from experience. Had the owner of a company I supplied mugs to use the first one out of a batch of 200 and have his coffee leak out the bottom.
Epson d120 £51.00 from Epson
CISS £19.99 from ebay
Ink , i am looking
the only thing is if i buy these seperate , how do i manage this icc profile thing?
Also taking printer and ciss is brand new,can i just start right away with sub ink?
sorry guys , but i did say i was virgin
Ink , i am looking
That was my thoughts as well, was beginning to think Press had a hot spot, but all tests out OK. Hence trying to find a new supplier, don't do a lot of mugs per se (guess I should change my company nameAndrew wrote:I would think cracking noises are more to do with the ceramic mug rather than the coating. It might just have been a bad batch but if it persists I would swap mug supplier. Most pinging/cracking noises might not result in to many problems but if it happens often then you will get the odd one with leaks through hairline cracks when hot water is poured in and expansion takes place. All this I say from experience. Had the owner of a company I supplied mugs to use the first one out of a batch of 200 and have his coffee leak out the bottom.
Sharon
- Has thanked: 13 times
- Been thanked: 12 times
Jock, I would recommend getting a pre-filled CIS, when you're starting out it's important to be able to get the right support from your supplier. If you buy bts and bobs from here and there it makes it difficult. I did this with my 5050, bought it from one company and then got the inks from another. Now I'm having problems with it and it really makes it complicated.
I'm sure you've seen by now but the inks are very expensive. This is due to Sawgrass holding the small format patent and prices are therefore set. You'll still make a healthy profit if you set prices right though and the ink shouldn't give you any problems.
They are indeed Sharon, 10ozdraig wrote:Are they RN mugs Justin? Been having trouble with cracking noises with the ones from LW.
Sharon
I will take your advise and get my ole faithfull mastercard out
just going to browse for a deal now , i only need the printing side , i have press and papers.
- purpledragon
Hi Jock i think we,ve all forgot to mention the ink you wanna get is artanium ink cheap inks and cheap paper just dont work eg i get great results with artanium ink and trupix paper i tried a sheet of signal paper( you will get used to the brand names) and the differance was unbelievable in short i doubt id have half the repeat custom if i used signal all the time. If you bought a prefilled system of ink im pretty sure the profiles come with it order that lot and we will all sit back and wait for the questions cause youre bound to have loads.
one bit of advise though BUY CHEAP BUY TWICE in this game thats definatly true. but hey us ugly mugs here are always on hand to give advice
Brett
Brett
Thanks Brettpurpledragon wrote:Hi Jock i think we,ve all forgot to mention the ink you wanna get is artanium ink cheap inks and cheap paper just dont work eg i get great results with artanium ink and trupix paper i tried a sheet of signal paper( you will get used to the brand names) and the differance was unbelievable in short i doubt id have half the repeat custom if i used signal all the time. If you bought a prefilled system of ink im pretty sure the profiles come with it order that lot and we will all sit back and wait for the questions cause youre bound to have loads.
Brett
i have taken all onboard and i think i will go with the printer D120 from BMS.
money is tight so,dont really want to be buying twice like you say mate, thanks for all the advise
