craft robo
Re: craft robo
so looks like its the cameo from mdp and the a1 cutting mat (+ free knife)
cheers all
Ill be back with another question laters ...................
cheers all
Re: craft robo
The craft robbo is an excellent machine and if used right - the only limit is your imagination.
It has restricted width of cutting but if you plan your designs around this then you can't go wrong. I have had 2 large cutters since getting my craft robbo on day1 - to be honest I have never used the large ones as everything was cut on my CR.
I sold one (as new) before Xmas and I have another large cutter sat here that I have done a test cut but that's it as I use the CR all the time.
As an example, the t-shirt I mentioned the other day (the post: my nightmare weed: below) was ALL done on my craft robbo
Re: craft robo
yep seen them adam - really nice indeed,but the weeding of it wouldnt be.The text alone would of been a nitemare to do - never mind all the bits on the dragon.
Re: craft robo
Dragons look easy compare to the text
Re: craft robo
how long do them sticky back carrier sheets last for as on many posts i see people saying they have spares ?
Do they lose the grip on the paper pretty badly ?
one final thing - for testing purposes only - can normal a4 paper be put into the machine so dont mess up on using EXPENSIVE vinyl
Re: craft robo
how long is a piece of string?????
when doing vinyl it usually has a backing depending on what your doing so you don't need the carrier sheet
but you will need it for paper
and yes you can put a normal A4 piece of paper thru it no problems
Re: craft robo
i NEVER used carrier sheet for flex or flock. they always cutted fine.
